dougie pumpkin Posted November 15, 2007 Report Share Posted November 15, 2007 (edited) How the hell do you get the rear break pedal out ? I have removed the allen key bolt where the pedal pivots , the spring and plunger removed and then the pedal seems to be free . But can i hell as jiggle it out ! Is there a special technique ? Or is it a total dismemberment of the rear end ? Forgot to say that the pedal is very slightly bent and i do mean very slightly. All help greatly appreciated . Cheers Edited November 15, 2007 by Dougie Pumpkin Quote Link to comment Share on other sites More sharing options...
paul w Posted November 15, 2007 Report Share Posted November 15, 2007 if i remember correctly, i removed the folding tip and it came out backwards, i also seen to remember having to get someone to sit on the bike to get the right heightto remove it ? sorry i was'nt on more use paul Quote Link to comment Share on other sites More sharing options...
dougie pumpkin Posted November 15, 2007 Author Report Share Posted November 15, 2007 if i remember correctly, i removed the folding tip and it came out backwards, i also seen to remember having to get someone to sit on the bike to get the right heightto remove it ?sorry i was'nt on more use paul I removed the toe tip as well, still o joy.. but will try getting the mrs to sit on it. Thanks Quote Link to comment Share on other sites More sharing options...
betabonkers Posted November 15, 2007 Report Share Posted November 15, 2007 They do come out with a struggle, i done two on my 06, cant remember which way though sorry. Quote Link to comment Share on other sites More sharing options...
kinell Posted November 15, 2007 Report Share Posted November 15, 2007 will try getting the mrs to sit on it. Thanks Never mind that, get back in the garage and sort the pedal out Quote Link to comment Share on other sites More sharing options...
paul w Posted November 15, 2007 Report Share Posted November 15, 2007 QUOTE(Dougie Pumpkin @ Nov 15 2007, 03:12 PM) will try getting the mrs to sit on it. Thanks Never mind that, get back in the garage and sort the pedal out now THATS funny! Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted November 16, 2007 Report Share Posted November 16, 2007 Ha Ha - That indeed - got a chuckle out of the old guy. Quote Link to comment Share on other sites More sharing options...
dougie pumpkin Posted November 16, 2007 Author Report Share Posted November 16, 2007 Never mind that, get back in the garage and sort the pedal out When i pressed the add reply button, i knew someone would say something, just dint have time to change it Quote Link to comment Share on other sites More sharing options...
markus Posted September 27, 2008 Report Share Posted September 27, 2008 Just pulled the rear brake pedal off my 2004 Rev 3. This is what I did. (1) Undo allen bold (2) Remove brake rod clip & detach rod from pedal (3) Remove chain spring slink & remove chain (4) Joggle the rear pedal up & back and remove threaded bush from rear of pedal (5) Pedal will not feed out forwards from frame Worked for me. I believe removal of swinging arm also works but sounds a bit more work. Good luck. Quote Link to comment Share on other sites More sharing options...
betabro Posted September 27, 2008 Report Share Posted September 27, 2008 I found when we put weight on the bike it opens up the clearance for the lever and it slides out. Same going back in. Quote Link to comment Share on other sites More sharing options...
