jack_h Posted November 17, 2007 Report Share Posted November 17, 2007 hey all, on a mikuni carb which way do you turn the mixture screw to make it leaner? thanks Jack H Quote Link to comment Share on other sites More sharing options...
mad4it Posted November 17, 2007 Report Share Posted November 17, 2007 You scerw it in to make it leaner Jack! Quote Link to comment Share on other sites More sharing options...
fkrisztian Posted November 17, 2007 Report Share Posted November 17, 2007 I disagree, I believe that for making it leaner you need to turn it out (i.e. anti-clockwise). Quote Link to comment Share on other sites More sharing options...
kinell Posted November 17, 2007 Report Share Posted November 17, 2007 Which side of the carb is the screw on? Nearer to the airbox or the engine? If airbox, unscrewing = more air (leaner) If engine, unscrewing = more petrol (richer) *DISCLAIMER* The above might be utter b*****ks, as I can't remember either Quote Link to comment Share on other sites More sharing options...
andy m Posted November 17, 2007 Report Share Posted November 17, 2007 Well as an ex M/C mechanic it was always out for leaner and in for richer(shutting off the air) never the other way round. 3 x City and guilds in the subject. But as I tell folk I have forgot more than I ever knew. Quote Link to comment Share on other sites More sharing options...
dan williams Posted November 18, 2007 Report Share Posted November 18, 2007 Out is leaner on the Mikuni VM carbs. The mixture screw on the mikuni is in the air circuit. Out is richer on the Del Orto because the mixture screw on the Del Orto is in the fuel circuit. Dan 1 Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 18, 2007 Report Share Posted November 18, 2007 Kinell said: Which side of the carb is the screw on? Nearer to the airbox or the engine?If airbox, unscrewing = more air (leaner) If engine, unscrewing = more petrol (richer) *DISCLAIMER* The above might be utter b*****ks, as I can't remember either In my experience Mr Kinell is right. You can check by going to both extremes, you should be able to tell if its too rich or weak Quote Link to comment Share on other sites More sharing options...
tomskiy Posted November 18, 2007 Report Share Posted November 18, 2007 Hi Jack_H, Kinell is correct! If the mixture screw is between the carburetor slide and the airbox, the screw controls the amount of air and should be turned outwards, anti-clockwise to lean the mixture. If the mixture screw is between the carburetor slide and the engine, the screw controls the amount or fuel and should be turned inwards, clockwise to lean the mixture. Quote Link to comment Share on other sites More sharing options...
gwrev3 Posted November 18, 2007 Report Share Posted November 18, 2007 Link below for Mikuni manual. The graph on page 10 shows that as the mixture screw (air screw) opens,the flow of fuel decreases, therefore the mixture becomes weaker....alegedly! http://www.mikuni.com/pdf/vmmanual.pdf Quote Link to comment Share on other sites More sharing options...
dan williams Posted November 19, 2007 Report Share Posted November 19, 2007 I'm beginning to understand why you guys have so many problems getting your bikes to run right with the Mikuni. Dan Quote Link to comment Share on other sites More sharing options...
gwrev3 Posted November 19, 2007 Report Share Posted November 19, 2007 GWREV3 said: Link below for Mikuni manual. The graph on page 10 shows that as the mixture screw (air screw) opens,the flow of fuel decreases, therefore the mixture becomes weaker....alegedly! http://www.mikuni.com/pdf/vmmanual.pdf ....oops! Meant to say the flow of air increases! Quote Link to comment Share on other sites More sharing options...
