Cluch Worries 315r
yamahaty250xox
hi all
i had a badly dragging clucth on my 99 315r so this weekend i have;
1 changed all the plates
2 changed the oil (silkoline comp 4t)
it still drages like a :thumbup::wall:
plus it has a "bite" when you pull the lever in???
what could be the problem?
any help welcomed
thanks
max
Edited by yamahaty250xox
What helped me with my 4rt was pushing the dot 4 clutch fluid upwards instead of downwards,i also put a gas gas hose on instead. When i put the new hose on i did away with the swivel joint . The ELF oil improved it also, Hope this is some use to you.
