Ajp/apico Lever On Sherco Clutch
craig10
Anyone tried fitting the Apico forged AJP lever on an 03 Sherco clutch? I've just tried it but the distance from the lever pivot to the push pin is out by about 3mm. The front brake one is ok because it has a bigger distance from the pivot to the piston centre line.
Has the 03 got a different clutch master cylinder to other bikes with AJP cylinders or have Apico made a b*lls up?
