Tlr 200 Forks
steve
Thanks guys.
Just bought them off EBAY for a project bike, hope they will work ok, they're Showa so I figured I couldn't go wrong.
I used to ride a mates RTL and loved the forks on that, are these the same?
ATF is roughly 7.5weight oil according to Honda
The oil capacity of 295cc +/- 2.5cc in each leg is for rebuild only - when you change the oil you should set the oil level since inevitably there will be some oil left.
Honda manual quotes the oil level fully compressed with spring removed as 118mm from top of fork leg
The RTL forks and TLR forks are not the same. The RTL forks are lighter & slightly shorter They can be identified by a waisted profile rather than straight profile
Gordon
Mistake on my part
Correct info below - I should have checked what each set of forks are rather than rely on memory! I have a TLR 250 with RTL forks - hence the confusion
ATF is 10 weight oil according to Honda - I have also been told its 7.5wt - but it depends on who you speak to and what bike you have!
For TLR's The oil capacity of 295cc +/- 2.5cc in each leg is for rebuild only - when you change the oil you should set the oil level since inevitably there will be some oil left.
The TLR forks have a waisted profile while the RTL forks have a straight profile.
The TLR forks are single spring while the RTL forks have 2 springs.
Interestingly Honda quote SS7 oil for RTL forks - this is 5wt oil, originally they quoted SS8 oil - this is 7.5wt.
Gordon
