Gasgas Tricks Bits
pancho247
Pah! Gasser pro's cannot be improved. They are perfect as they come.
:shutup:
True, but you can still install a few things to keep it as perfect as the first day like header pipe guards, handle bar end caps, etc.
Also, you can set it more to your liking with grips, handle bar bends, suspension, etc.
As Tim mentioned, there is not much to do on these bikes, just a few setting up chores to keep the bike fettled. From new, pack out the steering head, s/arm and linkage bearings with a waterproof grease. We use 10T gearbox sprockets down this way, most find the standard gearing a bit high. With a 10T spkt, you'll soon need the larger chain eccentrics or can fit a half link in the chain. Change out the gearbox oil after the first trial from new. Good idea to fit a carbon fibre ex shield, save melting your pants.
Bye, PeterB.
There are three bits that can improve the Perfermance of the PRO. The First is the Kehin Carb this improves response and seems to widen the Power band espcially at the top end. Then you can change the Rear shock for an Ohlins. NYL thinks it's less "sticky" when hopping around and it does improve the traction. Lastly there is the Titanium Front pipe. The long pipe softens the engine the short increase's the power.
I have also seen the S3 cover which allows you to change the clutch response but changing the Standard Clutch resevoir to a larger one does that and is a lot cheaper.
gasgas are the best bikes!!!!
but there is a new thing out wich is great, recently i put a new chain tensioner block on which i got from the dirt bike show from and it is great!, it stops the tensioner arm from being bent/ being snapped as it has a chopped off corner on it, and looks great too!!!!
