ally Posted December 28, 2007 Report Share Posted December 28, 2007 i have a sherco albert cabestany 06,the last time i was trialing on it,it stalled about riding it for about 30 mins,couldnt get it to go again at teh trial,came home with it cleaned out the carb gave it a service,yesterday whilst out trialing on it after 20 mins of the bike running it went off,changed the plug after the second kick it started again,it ran for about 15 mins then it stalled again,couldnt get it to kick over still after about 15 kicks still wouldnt,so i bumped it and it went,switched the bike off while waiting then it wouldnt go again,put a new plug in it went again then after about 20 mins then stalled again,came home with teh bike started after about 11 kicks ran for about 10 mins switched it off,then wont start again please has any 1 have any ideas what this can b it has me mad,,,,,,,left to rottt Quote Link to comment Share on other sites More sharing options...
motofire Posted December 28, 2007 Report Share Posted December 28, 2007 Where are you from? Has there been a weather change that affected your carb jetting? Is the fan kicking on? Coolant full? Air filter clean? If yes then I would take a good look at the carb and make sure its clean. Quote Link to comment Share on other sites More sharing options...
beta bodger Posted December 28, 2007 Report Share Posted December 28, 2007 I hate problems like these! Most people will tell you (once everything is checked and clean) that its either carburation or electrics. Sounds electrical, but you will have to either get it into a bike shop or try and diagnose yourself. Either way be prepared for it to not work first time. Quote Link to comment Share on other sites More sharing options...
hop blip and a jump Posted December 28, 2007 Report Share Posted December 28, 2007 It does sound more electrical than fuel, look at the obvious first Check all the electrical connections, clean the earths, check plug, cap and coil lead. if these don't make any difference get the coil, cdi and stator checked with a multimeter. The thing that makes the problem harder to find is that it's a stinkin intermitent fault!!!! Quote Link to comment Share on other sites More sharing options...
dabomb Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) Could be the stator.Symptoms of a dodgy stator are bike runs for 20mins then stops.wont start `till engine has cooled.Start engine again,stops again ofter 20mins. I had this problem on my 290,new stator sorted it. Hope this helps Also check for chaffed wiring in the area under the fuel tank,my mates bike had problems with this,but it was the cooling fan that wasnt coming on due to a chaffed wire earthing out,worth a look though Edited December 28, 2007 by dabomb Quote Link to comment Share on other sites More sharing options...
dan williams Posted December 28, 2007 Report Share Posted December 28, 2007 If it's just suddenly shutting off I'd agree that it sounds electrical. A defective kill switch will do this. Quote Link to comment Share on other sites More sharing options...
ally Posted December 29, 2007 Author Report Share Posted December 29, 2007 hi.... just want to thank every body on there advice on my sherco i will try all of the following info ,people have kindly gave me .. if none of these work its getting left to rottttt .. thanks again ally Quote Link to comment Share on other sites More sharing options...
