Two Cracked Valves And A Broken First Piston Ring !
honda_tlr
Think I know the reason for the TLR not running right , the first problem , the first piston ring was cracked , so was in 2 bits ! and the seccond problem , both valves appear to have hairline cracks in them !!
No wonder I couldn't get a the spark plug a nice colour !
Here is a picture of one of the valves, had a quick file at it and it does appear to be a proper crack, not just a casting mark!
On the pluss side m at least the head is now nice and clean :thumbup:
Now then , were is the best place to buy a set of piston rings and 2 new valves from? How much are they going to cost ? (about)
Usually valves would only crack around the seat area, never seen any cracked across the valve surface. Cause of valve seat cracks are down to insufficient tappet or valve clearence or ignition timing too advanced or a very lean mixture creating overheating. The plug would indicate this. Also, if the valve timing was set incorrectly. As for new ones, try your Honda dealer and if none available look for similar sized ones, either new or from a wrecker.
Bye, PeterB.
Your cracked valve is probably down to the production process, mass produced valves are usually two piece, welded together. 20 years of stopping and starting, with the metal being heated and cooled has probably released the internal stresses, your lucky the head of the valve didn't come detached from the stem. Gordon Farley M/c's keeps a good selection of Honda parts.
