What Fork Oil Weight Is Used As Standard?
beta bodger
Here's the link to RYP regarding the 2006 forks information:
http://www.shercousa.com/pdfs/2006fork.pdf
(The document was posted for the 2006 models at the time but I believe the same would be applicable to 2007 as well.)
Now for the oil weight, the document specifies "OJ RACING TYPE 01" - If you're interested in comparing this "OJ racing oil" with other brands, the folllowing chart gets useful:
http://www.gasgasrider.org/html/susp-oil.htm
Interesting to see that differents oils marketed under the same "weight number" don't actually have the same viscosity at all.
I guess someone has found that OJ Racing stuff, anyway, the Maxima looks close, I think! :rolleyes:
Wonder where the ATF fits in there? I never use it in the forks as it is required to have too much stiction! Viscosity is not everything you know! :unsure:
Edited by copemech
