Bad Starting
gee
i have a 05 290 its a pig to start cold seams mixture is week if i take plug out pour a small amount of petrol in it fires plugs not getting wet theres loads of compression and good spark
Check that the long brass tube that sticks out of carb ,when float bowl is removed is cleared out. That`s the choke circuit, has a small o-ring on the end that gets cut aswell. Chamfer the float bowl where the o-ring fits in. Always left sharp by Mr Dellorto, causes many problems !!!!
ShercoH
