stoford Posted January 7, 2008 Report Share Posted January 7, 2008 Hi, Can anybody tell me what gearbox oil they're running in their 290 Sherco and/or what they'd recommend? Also what make of brake pads would you recommend? Cheers, Stoford. Quote Link to comment Share on other sites More sharing options...
ham2 Posted January 7, 2008 Report Share Posted January 7, 2008 Automatic Transmission Fluid (really) and Apico Gold Quote Link to comment Share on other sites More sharing options...
paul w Posted January 7, 2008 Report Share Posted January 7, 2008 (edited) ham2, what brand of ATF do you use? and do you buy the same grade SAE ? Edited January 7, 2008 by paul w Quote Link to comment Share on other sites More sharing options...
copemech Posted January 7, 2008 Report Share Posted January 7, 2008 (edited) The factory spec is 10-40 gear oil! It will make for a less grabby clutch. All depends on what you want! Edited January 8, 2008 by copemech Quote Link to comment Share on other sites More sharing options...
betapete Posted January 8, 2008 Report Share Posted January 8, 2008 rock oil!!!! available at discount price, mail order from me Quote Link to comment Share on other sites More sharing options...
ham2 Posted January 8, 2008 Report Share Posted January 8, 2008 paul w said: ham2, what brand of ATF do you use? and do you buy the same grade SAE ? It says atf dextron 3 on the bottle (I think..I'm at work at the mo),if that helps. It's easier to find than the recommended gearbox oil. Clutch is a little sharp I admit but it helps when you want to 'pop', if you catch my drift? Quote Link to comment Share on other sites More sharing options...
dfwilson Posted January 8, 2008 Report Share Posted January 8, 2008 Mobil 1 synthetic ATF works great in my SY-250. Cheers Doug Quote Link to comment Share on other sites More sharing options...
neo Posted January 9, 2008 Report Share Posted January 9, 2008 Here's my suggestion Castrol EDGE Sport 5W-30 http://trials.com.au/phpBB3/viewtopic.php?...p;hilit=Castrol http://www.castrol.com/castrol/productd ... Id=7013361 Believe it or not, it's the best thing for a Sherco since sliced bread. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
trh71 Posted February 2, 2008 Report Share Posted February 2, 2008 Hi, Am i just being thick? Is Castrol edge sport 5W-30 engine oil or gear oil? Sherco web site says 10-40 Will that be engine or gear oil, just got the bike and always had 4 strokes before. Its just i've got some Millers 10-40 (semi or fully synthetic, cant remember) engine oil in the garage, but don't want to put the wrong stuff in!!! Ta trh71 Quote Link to comment Share on other sites More sharing options...
honda_tlr Posted February 3, 2008 Report Share Posted February 3, 2008 EP90 light gear oil. Quote Link to comment Share on other sites More sharing options...
neo Posted February 3, 2008 Report Share Posted February 3, 2008 Neo said: Castrol EDGE Sport 5W-30http://trials.com.au/phpBB3/viewtopic.php?...p;hilit=Castrol An update on the link above http://trials.com.au/phpBB3/viewtopic.php?f=4&t=1087 But it's important to understand that there's a 3 way balance, between a well lubricated engine...a bike that "shoots off" from cold, when first put in to gear....and a clutch that has a progressive action (without squealing). Castrol EDGE Sport 5W-30 provides that balance to me. ....but I have had no success with any 10w-40 oil. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 3, 2008 Report Share Posted February 3, 2008 Stoford said: Hi,Can anybody tell me what gearbox oil they're running in their 290 Sherco and/or what they'd recommend? Also what make of brake pads would you recommend? Cheers, Stoford. It would help if we knew where in the world you were? I always used atf/tqf in the UK its cheap available everywhere and can be changed frequently. Quote Link to comment Share on other sites More sharing options...
mick annick Posted February 3, 2008 Report Share Posted February 3, 2008 honda_tlr said: EP90 light gear oil. When I was a mechanic 'EP90' and 'light gear oil' were very different things Mick Quote Link to comment Share on other sites More sharing options...
