scorpa4banger Posted January 9, 2008 Report Share Posted January 9, 2008 I have a sy 250 07 is it normal to get some back oily crap drippling out from underneith exhaust flandge on the front pipe where it bolts onto the motor ? its not much but usually if I run it for a while you can see drips comming out .. Running motul factory 2 stroke oil at 70 - 1 with the fuel mixture screw out 1 3/4 turns .. just unleaded fuel also any ideas ? , the two flandge bolts are tight too.. only had the bike from new since september/october this year Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted January 9, 2008 Report Share Posted January 9, 2008 hi mate the only way i can think of is taking the front pipe off anf fitting a new exhaust gasket. if you do this i find it best if it is fitted in with 'exhaust paste'. im not too sure what make mine is but i wi have a look later. Quote Link to comment Share on other sites More sharing options...
arnoux Posted January 10, 2008 Report Share Posted January 10, 2008 Reasonably common problem, probably due to never having torqued the bolts properly at the factory, or the owner not retorqueing after running in the motor (have you done your cylinder head bolts?......) Easily fixed with a judicious use of exhaust sealant. Remove the header pipe (a cut down allen key makes removal of the left hand side bolt heaps easier). Leave the original gasket in place and apply a full circle of a fine bead of sealant to the exhaust flange. Refit and torque down. Leave it to go off before starting the motor. I like to use the PermaTex High-Temp copper coloured gasket sealant, but there is many brands and types available. It will cure the leak if applied properly. Quote Link to comment Share on other sites More sharing options...
bondy Posted December 24, 2017 Report Share Posted December 24, 2017 hello what is the torque for the exhaust flange? Quote Link to comment Share on other sites More sharing options...
