Which Mikuni Standard On Techno 250 (97)
lucky7s
Hi All,
Apologies if this has been asked a million times before but i only had the bike a couple of days and i'm completely new to trials bikes. My carb appears to be in need of a strip and clean - dropped the bike earlier and the float appears to be sticking open.....steady stream of fuel from the overflow pipe on the carb bottom. I need to get a gasket kit or whatever to do this i expect but i'm not sure what model mikuni is fitted. Any suggestions gratefully recieved, plus any tips on setting it up :thumbup:
After a bit of searching i found that its a VM28 (left hand model). Discovered that the one on my bike has had a lashup repair done on it anyway - the bottom of the carb body has been cracked off where it meets the gasket to the float bowl, and has been sealed with silicone sealer. Not a great job really, and its seeping a bit. I sourced a supplier of these carbs and got a new old stock one for 56 quid delivered - will just need a rejet. Beta UK are looking for around 130 plus the vat i think for the same one, so a pretty decent saving. If anyone else needs one let me know and i'll give you the guys contact details :thumbup:
hi there. welcome to wonderful world of upside down motorcycles.
set up hints for techno carbs.
like you i have recently got myself an old techno having just returned to trials after a 12 year plus lay off and experienced what sounds like the same fuel leaking problems (mine even leaked on the side stand with fuel tap on).
have a read through the page on this link http://www.r2wtrials.co.uk/html_files/betacarbsetup.html and make adjustments to float stopsas shown, its also worth carrying out the mods to the carb breather pipes as shown in this page http://www.ntxtrials.com/web_newsletters/RCR0106.pdf
i have carried out both these mods and it runs very well and doesn't try to dump its fuel at the first opportunity. hope this helps.
ps if your carb is a gonna check out ebay , i've seen a few techno's being broken for spares on there.
:shutup:
all the best Tim
:shutup:
all the best Tim
Hi tim, noticed your in cleveland, you up charltons this weekend??
