Sy250 Carb Breather Pipes
wuzzy
Hi there,
this is my first post so go easy on me folks!
Can someone advise please with a couple of issues.
1. I've refitted the carb on my 2001 SY250 2 stroke after fitting a new clutch slave cylinder & I'm not sure the best side to run the carb breather pipes (having replaced them). If I run the right one down the right side it's in the way when operating the choke plunger but running both over to the left side takes them too close to the exhaust for my liking. I do have the three pipes held together under the carb but didn't pay enough attention when stripping it down. (I have the manual but the exploded diagrams don't help on this one.)
2. Also I would find digital photo's of the scorpa wiring from above with rear mudgaurd and tank removed very useful as there is heat damage to one of the connectors & I'd like to check if it's run as it should be. If someone could post a pic when they next have their bike in bits I'd really appreciate it.
Thanks in advance, wuzzy
