stufrog1 Posted January 25, 2008 Report Share Posted January 25, 2008 (edited) How does the cam chain tensioner work on the honda tl125?does the engine have to be running? Edited February 16, 2008 by stufrog1 Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted January 25, 2008 Report Share Posted January 25, 2008 It's either manual, in which case you need to slacken a lock nut and wind in the adjuster until it takes up the slack, then re-tighten. Or It's mechanical, which means a spring pushes the tensioner against the blade which takes up the slack. To stop the spring being force back under load, there is a simple toothed ratchet mechanism. Quote Link to comment Share on other sites More sharing options...
