edholland Posted January 29, 2008 Report Share Posted January 29, 2008 (edited) After seeing the video,s of Cabrianes and Robregordo i knew i had to have a twinshock. The first picture is how i got it, not very good looking but the engine sounds great and the clutch and gears work. Started with painting the tank orange (sorry purrists) the mudguards will be painted in orange or i will go for the grey color like on 348mate,s great looking 349. Will try to post the progress here maybe it will help others in the future Looking for advice on rear shocks i,ve seen some real nice Betor ones are they any good ? Edited January 29, 2008 by EdHolland Quote Link to comment Share on other sites More sharing options...
peterb Posted January 29, 2008 Report Share Posted January 29, 2008 Hello Ed, I also have a rebuild to do on a 348, 1979 model but I think I'll do the tank in proper red! The rear hydrabag shocks on mine are well used with split bags, might be able to fix them. I heard the Betors work ok but other shocks can be stronger, and dearer. Could you have a look at the rear hub, there is a steel insert in my one, forming the housing for the sprocket side wheel bearing which looks like it has been engineered after the bike left the factory - or is this standard? I always preferred Bultaco's. Those bars look like 6.5 inch Renthalls, all the rage in the 70's. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
greeves Posted January 29, 2008 Report Share Posted January 29, 2008 I wish I could find one like that at the same price. It looks a first series as the kit has Rathmell Quote Link to comment Share on other sites More sharing options...
edholland Posted January 29, 2008 Author Report Share Posted January 29, 2008 Peter will make some pictures for you tomorow ! Senor Greeves i,m not sure mine is a MR replica i think just the tank. Quote Link to comment Share on other sites More sharing options...
edholland Posted January 30, 2008 Author Report Share Posted January 30, 2008 (edited) Pictures for Peter, the steeringwheel is from Renthal yes it,s huge ! perfect for me i,m 6,3 Edited January 30, 2008 by EdHolland Quote Link to comment Share on other sites More sharing options...
peterb Posted January 30, 2008 Report Share Posted January 30, 2008 Hi Ed, thats very nice of you to go to the trouble to photograph the rear hub, thanks. Not quite what I was looking for though, I was trying to find out what the set up was inside the rear hub, on the brake side, to see how that side wheel bearing is housed. Mine has a bad fitting steel sleeve fitted into the aluminium casting, doesn't look original. If you have the time, could you photo the inside of the hub please. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
edholland Posted January 30, 2008 Author Report Share Posted January 30, 2008 Peter i understand what you mean now will make the pictures for you ! but first i will do a few oil changes and just ride the bike to see what i need. If you are in a hurry i can take out the rear wheel and make the pictures no problem ofcourse. Cheers, Quote Link to comment Share on other sites More sharing options...
peterb Posted January 31, 2008 Report Share Posted January 31, 2008 Thanks Ed, There is no rush, you could PM me the photos when you have time. I am flat out getting my latest project ready for a practice this weekend! Thanks again, PeterB. Quote Link to comment Share on other sites More sharing options...
edholland Posted January 31, 2008 Author Report Share Posted January 31, 2008 Took off the rear mudgaurd and found some problems there. Does anyone have a picture of the white part for me ? the part is warped badly because of the melting from the exhaust. I can,t find this part anywhere for sale so i think i will have to repair this one. Quote Link to comment Share on other sites More sharing options...
peterb Posted January 31, 2008 Report Share Posted January 31, 2008 Hi Ed, My 348 is over in the school workshop, I have an original rear guard with it and will photo that area for you, then ask Tim to show me how to post the photo on here, thanks Tim. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted January 31, 2008 Report Share Posted January 31, 2008 Pete, mail me the photo and I'll post it. BTW there was an aperture for the exhaust to pass through. The heat has made it bigger. Ed, you can't get those mudguards anymore. The last set went to Jared Bates and he's sold them. The 349 mudguards are a fit but slightly narrower and are white. The 348's are slightly wider and a sort of opaque/pinkish white. Pete I'm stuffed if I can remember what the bearing carrier on the rear wheel looked like. Quote Link to comment Share on other sites More sharing options...
edholland Posted January 31, 2008 Author Report Share Posted January 31, 2008 Quote The 349 mudguards are a fit but slightly narrower and are white that would explain the tire marks in the part and mine are white and look to be cut off short. Must be a 349 part cut to use the still available mud guard. Quote BTW there was an aperture for the exhaust to pass through. The heat has made it bigger. ahhhh that explains it Tim i can see a shape clearing the exhaust but it,s a bit messy i,m sure Peter,s picture will help. Thanks Tim ! Cheers, Quote Link to comment Share on other sites More sharing options...
edholland Posted March 15, 2008 Author Report Share Posted March 15, 2008 After looking good at my Cota Fiasco 348 not one part on it is original. It has wheels from a later model the carb is a 22mm Amal the tank from a Rathmell replica it,s a mess. The 22 mm Amal is way too small but I have a good working carb on my 95 Fantic Section is it possible to use that on the Montesa ? Cheers, Quote Link to comment Share on other sites More sharing options...
