tony283 Posted January 31, 2008 Report Share Posted January 31, 2008 Should I ever be lucky enough to get a ride in the Pre 65 Scottish, and as my Cub wouldn't be popular, can the panel of experts, Chaired by Big John, please put this machine through scrutineering The carb is made by Mick Uni ( the well known ex pat) and they were around in the 60's I believe? Tony Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted January 31, 2008 Report Share Posted January 31, 2008 Should I ever be lucky enough to get a ride in the Pre 65 Scottish, and as my Cub wouldn't be popular, can the panel of experts, Chaired by Big John, please put this machine through scrutineering The carb is made by Mick Uni ( the well known ex pat) and they were around in the 60's I believe? Tony FWIW Cant see the tyres but assuming they are tubed NOT tubeless the only obvious parts are the carb, which is easy to correct, and the forks that might cause a problem. The purists may have appoplexy at the colour but we are supposed to broad minded nowadays A bike built to your own preferences and i am sure you are very proud of it. One question the footrests seem incredably low slung. How do you get on with them especially in ruts and over and around rocks? They lok like they would snag very easily but that may just be the angle of the photo. The onus on elegibility at the Scottish Pre65 is very much down to the entrant and only becomes a probem when somebody lodges a protest. Obviously the carb is a no no but otherwise ? Thaks for sharing anyway. Be interesting to hear "BJ the Judge" view Quote Link to comment Share on other sites More sharing options...
tony283 Posted January 31, 2008 Author Report Share Posted January 31, 2008 OTF, It's an original ex-works RE 350 Bullet prepared originally by DON MORLEY! Last ridden in the Pre 65 in 2005. The Forks and front wheel are ALL genuine 1960 RE, save for a new Akront rim. Tubed IRC front and rear, you can see the rear security bolts Mick will be upset you don't like his carb. Colour selected to contrast with the "Gaunt Edition" Footrests position, head angle all copied from Beta. Also where they are may look low but it has 12" ground clearance! a little more than the original 5.5" when it left the factory. All the construction details are on my blog in the November articles, this one is called "Reshaping a Bullet" Tony Quote Link to comment Share on other sites More sharing options...
davieboy Posted January 31, 2008 Report Share Posted January 31, 2008 Very nice bike. A lot to polish after a muddy trial mind. Quote Link to comment Share on other sites More sharing options...
big john Posted February 6, 2008 Report Share Posted February 6, 2008 OTF, It's an original ex-works RE 350 Bullet prepared originally by DON MORLEY! Last ridden in the Pre 65 in 2005. The Forks and front wheel are ALL genuine 1960 RE, save for a new Akront rim. Tubed IRC front and rear, you can see the rear security bolts Mick will be upset you don't like his carb. Colour selected to contrast with the "Gaunt Edition" Footrests position, head angle all copied from Beta. Also where they are may look low but it has 12" ground clearance! a little more than the original 5.5" when it left the factory. All the construction details are on my blog in the November articles, this one is called "Reshaping a Bullet" Tony I have been looking for this article and was obviously searching in the wrong place. Yes I can vouch for this bike being ridden in 2005 by Wullie Stewart from Lochinver! OK Tony has done a lot of work on it, only slight snag is the carb. They won't knock it back for the colour, I quite like it after all the works reps were a funny colour of green frame in 1959! I spotted the IRC rear and presumed it had a tube in there, again not a problem. It's definately not that trick I bet she still weighs a good bit then? Bring it over...I would stick an entry in for 2009 if I were you and I think given your personal history at the SSDT, which, again can all be vouched for... Big John Quote Link to comment Share on other sites More sharing options...
toofasttim Posted February 7, 2008 Report Share Posted February 7, 2008 I liked the Enfield green and I like Tonys purple. Quote Link to comment Share on other sites More sharing options...
tony283 Posted February 7, 2008 Author Report Share Posted February 7, 2008 Thank you for the once over. For the history buffs Mikuni had manufacturing rights for AMAL since 1932!! and produced their "own" carbs from 1949 onwards so in my humble opinion that makes them just as legal as some Maybe Villiers Lawnmower carb??? Strange there is all the fuss about front forks with modern internals yet nobody is bothered with the latest rear shocks from Betor? I had a Mikuni on my 1972 Sherpa which was only 7 years later than the cutoff so I'm assuming a Mikuni was available back in 64? Rules are Rules! Tony Quote Link to comment Share on other sites More sharing options...
baldilocks Posted February 7, 2008 Report Share Posted February 7, 2008 I dont think those grips are pre 65 and the side pull throttle definitley isnt BANNED !! Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted February 7, 2008 Report Share Posted February 7, 2008 (edited) Did they have that colour of paint before 1965...thought everything was black and white back then YUP BANNED to be honest sod the rules i think it's gorgeous Edited February 7, 2008 by Slapshot 3 Quote Link to comment Share on other sites More sharing options...
big john Posted February 8, 2008 Report Share Posted February 8, 2008 Oh yes Tony, forgot to ask, what air did you put in the tyres, did you use a Pre65 airbottle? If not, you may be banned! Big John Quote Link to comment Share on other sites More sharing options...
tony283 Posted February 11, 2008 Author Report Share Posted February 11, 2008 Thanks once again, Yes I do have some vintage Doherty grips, you know the ones that leave the palm of your hand Jet Black and don't like oil or petrol anywhere near them! With regard to air, it was "hand pumped" using 1946 forearms and shoulders. The purple colour came from a "Scottish Thistle" Tony Quote Link to comment Share on other sites More sharing options...
big john Posted February 12, 2008 Report Share Posted February 12, 2008 I knew it! There is still a source of Docherty style handlebar grips you know! I was hoping you had an old air-bottle with genuine pre-65 air inside. I suppose 1946 forearms are a viable alternative and therefore render the machine 100% authentic - PASSED! By the way can you grind down some thistles for me sometime Tony? Big John Quote Link to comment Share on other sites More sharing options...
greeves Posted February 12, 2008 Report Share Posted February 12, 2008 That is one of the bikes I dream with every night. Fantastic Quote Link to comment Share on other sites More sharing options...
tony283 Posted February 15, 2008 Author Report Share Posted February 15, 2008 Assuming the new Lucas Racing Mag works and somebody puts one of those awful Amal things on it then it would cost around the TEN or FIVE + a pristine 1972 250 Bultaco Got to keep up with Big John's current UK pricing! Tony Quote Link to comment Share on other sites More sharing options...
big john Posted February 15, 2008 Report Share Posted February 15, 2008 That is one of the bikes I dream with every night. Fantastic Quote Link to comment Share on other sites More sharing options...
