Scorpa Engine No
turnerboys
its under the centre section of exhaust but to see it is a load of work as you will need to strip out all the exhaust, rear subfame, air box
and rear shock if you do all this file away the corner of the casing were the middle exhaust sits so that it doesn't wear through the exhaust
It's a good idea to do this little mod anyway.
