Gas Gas Water Pump Seal
mikee
Is the water pump turbine threaded to the axis pin.. if so is it left hand or right hand thread..
gas gas 125 pro 2005...
trying to do the water pump seal....
Left-hand thread. Be sure to check the shaft for any significant grooves where the seal lips rode and if you find any, replace the shaft. The seal will last a lot longer.
Cheers.
Jon
