tlrbc Posted February 6, 2008 Report Share Posted February 6, 2008 Hey my fork is leaking, guess i could try heavier oil butt!!! any common honda or other bike that would have a similar fork seal or even fork that would be replaceable i am thinking of Carb parts and ignition too i have started building molds of plastic and will have carbon fiber and kevlar with vinyl-ester or epoxy regards tlrbc Quote Link to comment Share on other sites More sharing options...
g4321 Posted February 6, 2008 Report Share Posted February 6, 2008 any common honda or other bike that would have a similar fork seal or even fork that would be replaceable The seal is a common size - nothing exotic here. Can't remember whart bikes also use this seal but a search on an online parts shop (or better still visit to your friendly corner bike shop) should get the proper seals. Simple job for them to look in catalog from any parts supplier. Quote Link to comment Share on other sites More sharing options...
tlrbc Posted February 7, 2008 Author Report Share Posted February 7, 2008 1986 tlr 250r - g the local bike shop has said they are unable to cross to anything, and also not supply any U.S of A, parts or any import for that matter it is the only HONDA shop for 400km thanks tlrbc Quote Link to comment Share on other sites More sharing options...
brian r Posted February 8, 2008 Report Share Posted February 8, 2008 Would the seals have a number on the inside of them? There has to be something to use. ID,OD and height? Quote Link to comment Share on other sites More sharing options...
moleman Posted February 9, 2008 Report Share Posted February 9, 2008 The actual Honda part No you require is 51425-KT2-003 (2 of), they are 35mm id But they are easily available at any bearing supplier take them out and measure them, if i have an old set i will measure them , but i have probably thrown them out that is resuming you have a TLR250Rg (Monoshock , very quiet , mostly white ) you shouldnt need any ignition parts (apart from phyisical damage) but you may need a new float (brass and fiddly to solder) part No 16013-286-014 The oil filter is the same as an XR400 but the drain plug location takes a bit of explaining here if you need any more onfo just ask (assuming its a TLR250Rg ) Quote Link to comment Share on other sites More sharing options...
petertlr Posted February 9, 2008 Report Share Posted February 9, 2008 My honda dealership in Hawaii replaces them with those of a Honda VTR any year the USA part # is 51490-KBH-305. Quote Link to comment Share on other sites More sharing options...
tlrbc Posted February 9, 2008 Author Report Share Posted February 9, 2008 cool thanks Quote Link to comment Share on other sites More sharing options...
