Swing Arm Shim?
betarev3
Hi - I recently stripped down my rear swing arm to lube the bearings, and it was only when I started re-assembling that I noticed a shim/washer on the garage floor- doh! I'm not sure where it dropped out from, but is more of a shim than a washer as it is very thin. Anyone confirm where it should go? Exploded diagram seems to suggest it is a washer for the big nut, but that already has a washer integated into it....
First hand knowledge required please
