Keihin - Fuel- Air Mixture
silsdenrider
Lean or rich, you don't need to know. Set it by feel!
Set fast tickover. turn screw until you find where engine speeds up slighly, thats the spot.
However if you then check number of turns out from closed and its either half a turn or 3 turns or more then a diferent size pilot is needed.
Set this up on a mild day - it'll be diferent when the weathers really cold
