petertlr Posted February 9, 2008 Report Share Posted February 9, 2008 Just bought a '07 Rev 4T and I'm having problems with oil and antifreeze leaks that seem to be coming from the case and cylinder seals. I've never owned a Euro bike only Japanese so not sure what to expect. Is this common on Betas? What is the best fix? I realize the four stroke is so new most have no experience with them but any help would be appreciated. One dealer told me some leakage is normal and another said that they change the crankcase gasket and it is fixed (the 2 stroke). Quote Link to comment Share on other sites More sharing options...
betarev3 Posted February 9, 2008 Report Share Posted February 9, 2008 Hi - I have no specific knowledge of this engine, but generally if a seal starts leaking then it will need replacement, so would suggest this is done first. On disassembly, it may become evident why the leak has occurred, but if not, then at least you will know that you have started from a known condition and any further leaking will require 'expert' advice. Quote Link to comment Share on other sites More sharing options...
gasser Posted February 9, 2008 Report Share Posted February 9, 2008 Hi folks, I'm told that the coolant can erode the magnesium casing ( something to do with the amount of Mag in the casting ).....commonly about the water impeller cover. It tends to degrade the inner aspect of the channel of the seal and doesn't allow the cover to seal and sit correctly. Also from a recent conversation, it can degrade the water impeller bearing seat this can perforate, and allow coolant to wash around the clutch etc..... I also understand that those who need to know....know. Although I haven't heard what remedy is planned ( hopefully something definitive is in the pipeline). Interestingly, the price if the outer clutch casing has been significantly reduced ....! Quote Link to comment Share on other sites More sharing options...
rlracer Posted February 9, 2008 Report Share Posted February 9, 2008 Welcome to the 4-stroke world Peter. First leaking is not normal, second this is a four stroke right ? The case and pump is differant then the 2-stroke, the pump is in the head on the 4-stroke. Yes, I have had an 07 and have an 08 now. I'm trying to get a picture of what is going on, if you are having oil weeping around the head/cylinder area there is a fix for that. You say case area, where exactly bottom of cylinder ? center case ? clutch side case ? Coolant and oil mixing together or each leaking differant areas. Peter you can PM me if you would like. Quote Link to comment Share on other sites More sharing options...
totalshell Posted February 9, 2008 Report Share Posted February 9, 2008 gasser talks of a problem that affected 03 two strokes and has being discussed here before. the cure was cover replacement price Quote Link to comment Share on other sites More sharing options...
fullbore Posted February 9, 2008 Report Share Posted February 9, 2008 Pete i was looking over a NEW 4T recently and noticed anti leaking the bike had never been riden looks like a poor design Quote Link to comment Share on other sites More sharing options...
heathy3783 Posted August 24, 2024 Report Share Posted August 24, 2024 On 2/9/2008 at 5:34 PM, rlracer said: Welcome to the 4-stroke world Peter. First leaking is not normal, second this is a four stroke right ? The case and pump is differant then the 2-stroke, the pump is in the head on the 4-stroke. Yes, I have had an 07 and have an 08 now. I'm trying to get a picture of what is going on, if you are having oil weeping around the head/cylinder area there is a fix for that. You say case area, where exactly bottom of cylinder ? center case ? clutch side case ? Coolant and oil mixing together or each leaking differant areas. Peter you can PM me if you would like. I also have an 08 rev 4t noticed a leak so I fitted water pump gasket but it looks like could be oil from the the same area, have you had this problem and hair did you fix it please Quote Link to comment Share on other sites More sharing options...
lemur Posted August 24, 2024 Report Share Posted August 24, 2024 Oil in the coolant means you would also see coolant in the oil and that would almost certainly be the water pump seal. Just a hunch the part number also relates to the dimensions 12.30.7 oil seal Quote Link to comment Share on other sites More sharing options...
stu109 Posted August 25, 2024 Report Share Posted August 25, 2024 Hi I think this is the same engine as my Evo 4T The water pump shaft has two seals one to stop oil leaking into the coolant and one to keep the coolant in. There is a weep hole that allows coolant to leak out if it gets between the two seals. The shaft is prone to wearing. You can see if it is becuase it gets a groove cut where the seals rub. From memory, I think it is possible to replace the shaft without taking the head off. Stuart Quote Link to comment Share on other sites More sharing options...
