sheffieldtrials Posted February 11, 2008 Report Share Posted February 11, 2008 Alright guys iv recently purchased a gas gas GT32 in bits, When i came to putting it back together the swing arm was very very tight to fit in, and really had to stretch the frame for it to fit. Its now overly tight and im guessin not correct. the only spacers i could find where the ones attached the the bush that runs inside the swing arm bearings, iv currently got these on the outside of the swing arm touching the frame. Has any one got a GT32 or know how they the spacing is meant to be?? are there other spacers that im missing?? any help would be appreciated cheers Quote Link to comment Share on other sites More sharing options...
peterb Posted February 11, 2008 Report Share Posted February 11, 2008 Hi there Sheffieldtrials, There are two bushes that run inside the 2 pairs of needle rollers, these are the spacers that you refer to. These two bushes are inserted into the inside of the swinging arm such that the larger diameter faces up to the gearbox mounting area of the crankcase, they don't fit the other way round. There are no more spacers in this area. I liked the GT32, my first Gasser. Had stacks of bottom end go but didn't rev out too high. Was a bit rich on the main jet. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
dabomb Posted February 16, 2008 Report Share Posted February 16, 2008 Hi there Sheffieldtrials,There are two bushes that run inside the 2 pairs of needle rollers, these are the spacers that you refer to. These two bushes are inserted into the inside of the swinging arm such that the larger diameter faces up to the gearbox mounting area of the crankcase, they don't fit the other way round. There are no more spacers in this area. I liked the GT32, my first Gasser. Had stacks of bottom end go but didn't rev out too high. Was a bit rich on the main jet. Bye, PeterB. I agree with al of the above,i to had a gt 32,bloody heavy lump compared to my sherco,good bike though. Change the bushes round,job done Quote Link to comment Share on other sites More sharing options...
sheffieldtrials Posted February 18, 2008 Author Report Share Posted February 18, 2008 Nice one, cheers guys Quote Link to comment Share on other sites More sharing options...
