andat Posted March 3, 2008 Author Report Share Posted March 3, 2008 andat, Do you have the flat bash plate? If you do, you might consider elongating the access hole with a die grinder. This will allow a straight shot at the drain plug. It will help keep the hex head from rounding off when you use a socket wrench to loosen or tighten the plug. Ciao DFW Yes it's flat bash plate on a 2007 model. I have got a replacement sump plug from Birkett and the hexagon is f****ng massive compared to the original so I will definately follow your suggestion. Cheers DFW Quote Link to comment Share on other sites More sharing options...
timp Posted March 4, 2008 Report Share Posted March 4, 2008 Yep, Timp's method works. Cheers Mark Glad it helped.Got to do my bit to keep them running Quote Link to comment Share on other sites More sharing options...
