996mick Posted February 13, 2008 Report Share Posted February 13, 2008 have 01 280 when engine gets hot the fan cuts in but only for about 10 seconds then goes off again.had a beta and when that got hot the fan was on for quite a bit before going off.can some one who has a 280 tell me how long there fan stays on for.cheers (oh and how much is a piston for the txt280) Quote Link to comment Share on other sites More sharing options...
gjbiker Posted February 14, 2008 Report Share Posted February 14, 2008 Sounds like it's working fine to me ? If it's cutting in and out then the thermostat is doing its job but if you have any doubts, stick a new thermostat in (though it'll probably be just the same). Double check your coolant level as a low level will confuse the thermostat and also make the engine run hot. As for prices, give Gas Gas UK a call on 01298 766813 with all the details of your bike - frame/engine number, year, model etc. GJ Quote Link to comment Share on other sites More sharing options...
996mick Posted February 16, 2008 Author Report Share Posted February 16, 2008 cheers for that Quote Link to comment Share on other sites More sharing options...
