Fantic 300 Tech Info (timing In Particular)
chrisb7
Help! I have just bought a Fantic 300 but it doesn't run quite right. Thought I would check the timimg etc. Does anybody know where I can get a repair manual or if not tell me what to look for in setting the timing. I read somewhere that it uses a Champion N3 plug and the timimg settings are 2.5mm before TDC. Is this right? Also I couldn't see any alignment marks when I took off the magneto cover. Any help appreciated.
The timing marks on my 240 are at the base of the flywheel near the surface of the crankcase and they are not that easy to see as they are quite lightly stamped - it might be worth having another look for timing marks.
