Cota 200 Questions
sjs
Thanks for the speedy replys guys, bob pa usa could you give me the info for the 200, i will have to research and find out the correct year but could you give me answers for the 200 cota and we'll presume it's 1981+, just to clear up, what i meant by crankcase quantity was gearbox oil, thanks again bob pa usa, Steve
The manual lists the following:
Fuel Mix - 32:1
Fork Oil - 200cc of "Hidrol-7", which I assume is 7wt
Gearbox - 900cc of 10w30
Hope this helps. It's a good performer. Problems I've had have been gas tank leaks and the tranny popping out of gear. Adding a ball bearing to the detent spring at the top of the case helped a lot, but didn't eliminate the problem. Good luck. email me if you need anything else.
