1994 Jt 250 Contact
goz1960
Hi there,
The problem is most likely the radiator cap. As these get old, the seal deteriorates and so the coolant is not allowed to get up to pressure. try a new cap. Next thing to look for would be if the head O ring seals were passing, then the coolant would be over pressured, you may see this as white smoke from the exhaust system. I don't think there are any manuals for these bikes, quite a straight forward motor to work on, just need to ask on here if you need help.
Bye, PeterB.
