timerider Posted February 26, 2008 Report Share Posted February 26, 2008 Hi there, can anyone out there guide me through changing the fork oil seals on my 99 txt 250 please, and can you tell me the code number for the replacement ones ? cheers, much appreciated. Quote Link to comment Share on other sites More sharing options...
mikee Posted February 26, 2008 Report Share Posted February 26, 2008 (edited) This might be of some help too you... gas gas help or try this .....sherco fork seal replacement I know there for a sherco, but there nearly the same as the TXT.. hope it helps... Edited February 26, 2008 by MIKEE Quote Link to comment Share on other sites More sharing options...
jse Posted February 26, 2008 Report Share Posted February 26, 2008 This might be of some help too you...gas gas help or try this .....sherco fork seal replacement I know there for a sherco, but there nearly the same as the TXT.. hope it helps... Seal replacement is fairly straightforward, I think the part number is ST950220 for the seal. You'll want to use a little Silicone grease on the outer part of the seal to install it and I like to pack the area between the seal lips with grease. Each leg takes 300 (+ or -)cc's of 5 weight fork oil. Unless you're familiar with how to re-set the top cap damping adjustment after removal from the damper rod, it's probably best to remove the cartridge/spring assembly as a unit by taking out the "base bolt" from the very bottom of the lower leg. To not damage the seal lips putting it over the upper tube, cut a small triangle off the corner of a plastic sandwich bag and put it over the tube, the seal will slide over it on to the tube easily. Jon Quote Link to comment Share on other sites More sharing options...
timerider Posted March 5, 2008 Author Report Share Posted March 5, 2008 cheers for the advice guys, it`s much appreciated and has been a great help. Quote Link to comment Share on other sites More sharing options...
