trh71 Posted February 27, 2008 Report Share Posted February 27, 2008 Am i going mad?!! Right where do i start, I came off my 02 sherco 2.9 and snapped the clutch lever off, i got a pair of forged ones to go on, but the clutch one didnt fit, so i got another one (different make) and that dose'nt fit ether! Now i have to try and describe why not! From the center of the pivot bolt hole, to the center of the plunger is only 15mm on the clutch where the front brake is 20mm as are all the levers (both brake & clutch). It looks like the master cylindar has been drilled out wrong. But to confuse me more the orignal clutch lever mesures 15mm to match? I'll try and put some photo's on to describe better. I'm not sure what else i can tell you, if you could mesure the distance between the pivot bolt and plunger on your clutch, at least i'd know if its my master cylinder thats wrong. Can't work out how to put photos on sorry. Do Gas Gas's have the same master cylinders? I hope you can help me TIM Quote Link to comment Share on other sites More sharing options...
copemech Posted February 28, 2008 Report Share Posted February 28, 2008 I measured what I think you just described and came out 15mm on my '07! Quote Link to comment Share on other sites More sharing options...
motodaz Posted March 5, 2008 Report Share Posted March 5, 2008 Yes, GasGas do use the same master cylinders/levers (older ones atleast) , and my 04 sherco has 15mm gap aswell, hope this helps. Quote Link to comment Share on other sites More sharing options...
