Headlamp
dwdwdw
Hi,
the bulb in mine was a 12v 35w like used around the house, easily obtained for 99p and up.
I used to have a UFO headlamp unit which took two similar lamps. They are available in 50w and different
angles of beam width. I use my rev 3 fairly regularly on the road (6 mile commute to work), so I
fitted a Honda 4rt headlamp which has dip and main beams, still only 35w though.
hope this helps
Pete.
