How Far Forward Are Your Bars?
godzilla
On my sherco i just cant stop messing around with my bars; i used stock dominos but they seem to quite far forward to the point that i could undo all the bolts without undoing the cross brace the the serian number for the bars is directly between the front and back clamp bolts. Any advice on setup would be ace. this is the only time i have ever had this problem and its sending me mad.
i am 5.9 if that helps.
Going by Ryan Young, loosen the bars, put your straight allen wrench in the top bolt of the clamp, put your cross brace (with out the pad) up to the wrench, just touching. That should be a good starting position. The bars will be almost straight up and down.
With the allen key in front or behind?
