01 Rev Carb
jmorgan
Bought a 01 rev not running. Sent it out took a new cdi box and they cleaned the carb. I now have it back and i can get the bike to start for about 10 seconds then dies. Looking for the mixture screw settings for this bike Also a timing spec
Mixture screw 1 to 2 turns out,stator in the middle of the adjusting slots.Does it die after turning the choke off?if so its probably too weak.The timing can't be far out if it starts.Try the mixture screw,out is weaker.good luck
