billboat10 Posted March 6, 2008 Report Share Posted March 6, 2008 my rear brake lever is catching on my chain when moving any ideas hoe to cure it it dosent seem bent or worn but its driving me mad as i can feel the chain rubbing every link when i ride thanks Quote Link to comment Share on other sites More sharing options...
drop5 Posted March 7, 2008 Report Share Posted March 7, 2008 If the leaver has play side to side the needle bearing is worn. If the bush at the back is loose the bearing probably needs replacing as water gets in . Not expensive to replace,also change the bush as this is probably worn. The easiest way to remove the leaver is to remove the swing arm, only takes 10 mins. And you can grease the swing arm bearings while its apart. Trying to remove the leaver without removing the swing arm is a nightmare. Quote Link to comment Share on other sites More sharing options...
