thedktor Posted March 10, 2008 Report Share Posted March 10, 2008 I would like a workshop manual, ie for taking stuff apart rather than a high level maintenance type, is there anywhere to download? Seems to be a common question so could a sticky be added for newbies? Thanks Steve Quote Link to comment Share on other sites More sharing options...
thedktor Posted March 11, 2008 Author Report Share Posted March 11, 2008 Ah nice videos thanks. So no sign of a static paper type manual then? Steve Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted March 13, 2008 Report Share Posted March 13, 2008 http://www.gasgasmotos.es/eng/frame.htm Here you go! The owners manual and parts list is as close as your going to come to paper versions. You might also want to check the us website www.gasgas.com under the tech link. Lots of good info in there as well. --Biff Quote Link to comment Share on other sites More sharing options...
thedktor Posted March 17, 2008 Author Report Share Posted March 17, 2008 Thanks for that Biff. It would be nice to have a proper manual but seems like most stuff can be worked out from the combined information sources, and I suppose its not as if trials bike are ultra high tech, or indeed normally need a lot of disassembly! Steve Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted March 17, 2008 Report Share Posted March 17, 2008 Most stuff will only go back together 1 way and in a certain order. You usually find the correct order by trial and error at times. Couple of hints: If it does not go easy back up and remove any other related items. Most bolts go in 1 way for a reason so make a note of which side the bolt or allen head is on and the nut. If in doubt of where you are going take digital photos for yourself on tear down each step of the way. (this one is the most useful) Other than that they are a pretty simple machine in a relatively tight package. --Biff Quote Link to comment Share on other sites More sharing options...
