Pj1 Gear Oil Should I Swop To Another
beta bodger
Any alternatives worth using? Dextron III? Or should i just stick to the PJ1?
Personally, I would stick with the PJ1 or other proper gear oil unles for some reason you need the quicker bite of ATF, and even then not run the cheap stuff. High quality fully synthetic ATF is available. It is not inexpensive. :rolleyes:
I have been using Golden Spectro gear lube in my bike.
(my Dad swore by the stuff, he gave me a bunch when he quit riding.)
When that runs out I will probably check into Amsoil for gear lube (not sure what they got). I like their 2 stroke oil.
Just my personal opinion that ATF is for Automatic Transmissions, My bike is manual gears hence I go with a motorcycle specific wet clutch Gear lube. When I get an auto trans trials bike I will put ATF in it.
Stick with the PJ1.
