davieboy Posted March 15, 2008 Report Share Posted March 15, 2008 I have fitted a new stator to my 1999 Techno 200 and seems to be running fine now after a bit of trial and error with the ignition timing.I have retarded the timing about 2mm from the centre of the screws and it seems to be running ok.I will need to try a test run.Does anyone know the torque setting for the flywheel?I have it at about 70 Newton metres at the moment safely but do not want to go any tighter as I don't want to strip the threads. Quote Link to comment Share on other sites More sharing options...
bob Posted March 17, 2008 Report Share Posted March 17, 2008 The Rev3 torques up to about 140 Nm. I imagine that this is the same as on the techno which has a comparable ignition system. bob Quote Link to comment Share on other sites More sharing options...
davieboy Posted March 17, 2008 Author Report Share Posted March 17, 2008 The Rev3 torques up to about 140 Nm.I imagine that this is the same as on the techno which has a comparable ignition system. bob Thanks. The 99 Techno has the same ignition as the early rev 3's,I believe. Quote Link to comment Share on other sites More sharing options...
