garyh Posted March 16, 2008 Report Share Posted March 16, 2008 HI EVERYONE JUST REGISTERED AND GETTING INTO TRIALS. I HAVE RECENTLY PURCHASED A MONTESA 315 AND WOULD BE REALLY HAPPY IF SOMEONE COULD HELP ME OUT BY LETTING ME KNOW WHERE YOU DRAIN THE ENGINE OIL. THANKS. Quote Link to comment Share on other sites More sharing options...
bmartin Posted March 16, 2008 Report Share Posted March 16, 2008 hi there look under your sump plate theres a small hole that has a drainage allen key bolt.take it easy when replacing bolt easly cross threaded good luck and enjoy. Quote Link to comment Share on other sites More sharing options...
popeye Posted March 16, 2008 Report Share Posted March 16, 2008 hi there look under your sump plate theres a small hole that has a drainage allen key bolt.take it easy when replacing bolt easly cross threaded good luck and enjoy. i think you may be confused its the bottom bolt on side casing above the sump plate behind and just below gear lever,lean the bike over to drain Quote Link to comment Share on other sites More sharing options...
popeye Posted March 16, 2008 Report Share Posted March 16, 2008 what year is your bike Quote Link to comment Share on other sites More sharing options...
garyh Posted March 16, 2008 Author Report Share Posted March 16, 2008 THANK YOU FOR YOUR REPLYS I KNOW IT IS NOT UNDER THE BASH PLATE AS I HAVE TAKEN IT OFF. I WILL CHECK BEHIND THE GEAR LEVER. CHEERS Quote Link to comment Share on other sites More sharing options...
garyh Posted March 16, 2008 Author Report Share Posted March 16, 2008 ITS A 1999 Quote Link to comment Share on other sites More sharing options...
popeye Posted March 16, 2008 Report Share Posted March 16, 2008 if you pm me with e-mail details i have the manual in pdf format Quote Link to comment Share on other sites More sharing options...
garyh Posted March 16, 2008 Author Report Share Posted March 16, 2008 does anyone have any thoughts on which 2 stroke oil to use and what ratio to mix it for the montesa its 1999 Quote Link to comment Share on other sites More sharing options...
garyh Posted March 16, 2008 Author Report Share Posted March 16, 2008 if you pm me with e-mail details i have the manual in pdf format emmaandgary@hotmail.com cheers popeye Quote Link to comment Share on other sites More sharing options...
trialanderror Posted March 16, 2008 Report Share Posted March 16, 2008 Hi, put 80ml to 5 litres of fuel, as for which oil to use I swear by castrol but putoline, ipone, pj1, repsol are all good. hope this helps cheers Quote Link to comment Share on other sites More sharing options...
