boner Posted March 17, 2008 Report Share Posted March 17, 2008 Guys, was out riding over the weekend and noticed a rattling noise coming from somewhere... Upon further inspection I found it to be the front disc was vibrating as it has a little play. Thought that this couldn't be right - so checked all the bolts and found that they were all tight. So - took it all apart and cleaned it all up so that everything looked as good as new, put it back together again, and it was still loose! So my question is - is the front disc suposed to have a certain amount of play? Thanks - Boner. Quote Link to comment Share on other sites More sharing options...
scoti35 Posted March 17, 2008 Report Share Posted March 17, 2008 They are a sliding frount disc, tis is ment to happen! Quote Link to comment Share on other sites More sharing options...
phb Posted March 17, 2008 Report Share Posted March 17, 2008 yes the disc should have slight movement they are called floating discs Quote Link to comment Share on other sites More sharing options...
rapid roy Posted March 17, 2008 Report Share Posted March 17, 2008 Guys, was out riding over the weekend and noticed a rattling noise coming from somewhere...Upon further inspection I found it to be the front disc was vibrating as it has a little play. Thought that this couldn't be right - so checked all the bolts and found that they were all tight. So - took it all apart and cleaned it all up so that everything looked as good as new, put it back together again, and it was still loose! So my question is - is the front disc suposed to have a certain amount of play? Thanks - Boner. i hate rattles there should be play in the front disc i silicon around the cups of the disc stops the rattles and doesn't affect the braking performance Quote Link to comment Share on other sites More sharing options...
boner Posted March 17, 2008 Author Report Share Posted March 17, 2008 Ahhh - we'll at least I now have very clean (floating) discs! Thanks for putting my mind at rest on that one! Cheers - Boner. Quote Link to comment Share on other sites More sharing options...
razor Posted March 17, 2008 Report Share Posted March 17, 2008 i silicon around the cups of the discstops the rattles and doesn't affect the braking performance my mate just bought a 99 mont and his front disc rattles alot........ thanks for the silicon tip, Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted March 18, 2008 Report Share Posted March 18, 2008 In the past i have slipped an o ring between the cuped washer and the disc to quiet them down. Looks a little cleaner than silicone. It is ment to float. --Biff Quote Link to comment Share on other sites More sharing options...
bsmallinson Posted April 13, 2008 Report Share Posted April 13, 2008 Haha, being new to the scene and just having had a few rides out on my recently purchased '02 315R i have also noticed this rather annoying little rattle. Top tips guys!! Many thanks, Ben. Quote Link to comment Share on other sites More sharing options...
