Benly Powered
boner
Was observing at a local twin shock event last weekend, and someone had a Benly powered bike - which for me was bike of the day!
It had a lovely sound to it. Missed the chap at the end of the event, as I was still walking back, but found out from a friend that the chap had built the bike himself.
Was wondering if anyone else out there had a Benly powered bike?
Cheers - Boner.
Not exactly an early 1960s 125cc Benly twin, but here are some later 60's CB160/175 twin specials from my website. The first two are in the vintage dirtbike/trials photos:
"After two seasons running a 90cc Honda trials special, English dealer Ken Ives built a CD175 engined CB160 trials bike. Low compression, lower gearing, upgraded forks, trials spec wheel diameters and tires made a nice trials bike. Photos from 07 Feb 68 Motor Cycle."
http://www.eurospares.com/hon175t1.jpg
http://www.eurospares.com/hon175t2.jpg
From a page devoted to 160 trials bikes ( http://www.eurospares.com/cb160t.htm ):
A special that appeared in a 1969 magazine:
Mr. Deeter had overbored the engine to 180ccs, and fitted a single carb head from a 175 Honda. The compression was lowered (method not specified), a milder cam from a Honda CA was inserted, and a brass flywheel fitted to the back of the alternator rotor where the electric starter sprag clutch would normally go. He also built a 2-1 high pipe with fairly short head pipes and a very long tail pipe. The bike was lightened with an aluminum fuel tank from a Van Tech frame kit and Akront alloy rims (19" front/18" rear). A small hub from a Honda S90 was used in the front wheel, and attached to forks from a CL160. The bike was reported to weigh 215 pounds, and Mr. Deeter figured he had a year of part-time labor and $1000 invested in the project.
http://www.eurospares.com/deeter.jpg
As far as I've gotten with my CB160 Premier Lightweight special inspired by the above bikes:
http://www.eurospares.com/160a.jpg
http://www.eurospares.com/160b.jpg
http://www.eurospares.com/160pipes.jpg
I've grafted an 160 alternator (internal) rotor hub into an (external) alternator rotor from an EX250 Kawasaki Ninja to increase flywheel mass.
The ports have been filled on both sides
http://www.eurospares.com/160ports.jpg
Dished XR100 pistons:
http://www.eurospares.com/160pist.jpg
cheers,
Michael
Edited by MichaelMoore
If you can get a copy of YOU HAVE USED WORDS OR A PHRASE WHICH ARE NOT PERMITTED ON THIS WEBSITE. PLEASE DELETE YOUR POST/TOPIC. DO NOT TRY TO CIRCUMVENT THE FILTERS IN PLACE ON THIS WEBSITE issue 6 there is an article in it The Lejeune Honda Twins. An interesting write up. :gay:
cheers,
Michael
I'm afraid to ask why you use the URL for the photos instead of the IMG. Size of the pictures?
Dave, I've noticed that the threads here with a lot of photos (especially where people have "quoted" the original post with the photos several times) take a bit of time to load even with DSL so I thought I'd avoid loading 8 images and slowing things down for others. And anyone who wants to see them can easily click on the links.
Old-fashioned Internet courtesy habits can be difficult to break. :gay:
cheers,
Michael
Hello boner, there is two chaps in our club (wilts dorset mcc) that have honda twins. one is a in a beamish frame the other is completely home made .they both go well.
I reckon those are the same two that ride the Bath classic series - as stated they both go well and sound great when screaming their brains out !
cheers,
Michael
People who quote with pictures deserve to get chastised. Or better yet I've seen so BB software that doesn't allow it.
On open megaphones my "CR216" that I designed and built was measured by my local race club at about 130dB. That's pretty uncomfortable to be around in the pits but sounds good out on the track. This photo was at Laguna Seca before I installed the fairing.
cheers,
Michael
Hi OTH,
I had one of those Benley's about 40 years ago (I were just a lad). I thought the tank was a superb shape, yours is a good example. I seized the big ends, not cleaned out enough during a strip down (well, I was pretty young then), put in another motor then swapped it for a YS 1 I think (Yamaha 100 twin) plus cash - seized that too!
Bye, PeterB.
Gosh, you look away from your computer for two minutes - and you get loads of posts!
Scorpa250 - that's where i saw the bike, at Roger's meet. The bike in perticular was the Gazelle, sounded great - not too sure about the yellow and brown paint scheme though! Didn't spot the other Benly, will keep my eyes peeled on the 13th.
Some nice bikes out there - and some serious work. Thanks for the replies.
Cheers - Boner
