davidhiggins Posted March 20, 2008 Report Share Posted March 20, 2008 Hi all someone may be able to help. I have a Fantic 200 (1982) with different yokes to a friend of mine, the yokes on my bike set the handle bars back towards the petrol tank while on my mates bike they are probably 3/4 inch further forward.Both sets of yokes have two pinch bolts to secure them to the stantions. After riding both bikes I prefer the riding position on my mates bike so would like to change mine the question is where can I get a pair of yokes that set the bars to the front of the bike and did fantic produce two fantic 200 with different front ends. Also my mates 200 has a different cylinder head this I believe raises the compression, was this mod a works mod. Does it make them run better if so where can I buy a head. Thanks for your help Regards David Quote Link to comment Share on other sites More sharing options...
turbo Posted March 20, 2008 Report Share Posted March 20, 2008 yes the yolks were different i have several fantics and they vary .The ones that are more forward give a better steer.Ihave just fitted the fat bar conversion from classictrial ,this is a modified top yolk and is very effective. Quote Link to comment Share on other sites More sharing options...
fivemeister Posted March 20, 2008 Report Share Posted March 20, 2008 Looks like you have the standard 240 pro yokes. Most owners swapped these for the 200 version which were set more forward. May have been changed by a 200 owner who for some strange reason prefered the further back position of the 240??? Quote Link to comment Share on other sites More sharing options...
ask greeves Posted March 21, 2008 Report Share Posted March 21, 2008 Really, to answer the questions correctly, need to identify exact, which 200 you have, forward kick or back kick...kick start . Quote Link to comment Share on other sites More sharing options...
davidhiggins Posted March 21, 2008 Author Report Share Posted March 21, 2008 (edited) Hi the fantic 200 I have is a rear kick model Do both yokes need to be changed . One other question is the flywheel nut on a 200 left or right hand thread Thanks David Edited March 21, 2008 by DavidHiggins Quote Link to comment Share on other sites More sharing options...
ask greeves Posted March 21, 2008 Report Share Posted March 21, 2008 Hi, 1982 200 back kick, had same front forks as 240, identifiable by the rear mounted handlebars and flat type front mudguard bracket (fitting bolts go downwards) also seat should be rubber, not covered foam. Yes the earlier type, forward position top yoke, should fit straight on, without changing bottom yoke. The cylinder head from a 125, will fit , this ups the compression ratio, but not so docile at low rpm. As for flywheel nut, i work on the principal, 'if it don't undo 1 way, it'll undo the other'. Quote Link to comment Share on other sites More sharing options...
davidhiggins Posted March 22, 2008 Author Report Share Posted March 22, 2008 Thanks for the info regards David Quote Link to comment Share on other sites More sharing options...
