B40 Gearbox Sprocket - Changing
b40rt
Any help would be appreaciated. Haynes manual says you have to remove clutch, alernator, primary chain tensioner, and engine sprocket simultaniously (probably dropping all 25 beatings in the process) before removeing the cluth back plate to get access to gearbox sprocket. Is this the only way or are there any shortcuts ? Thanks.
Yep thats it :D Just think yourself lucky you havent got an unmodified cub cos then you have to split the crankcase also :hyper:
Then they wonder why the British Motor Cycle industry went down the pan ? :thumbup:
Thanks for the info, fortunatly the sprockets last well as long as you change the chain regularly.
