Rev 3 250
robm
A couple of weeks ago the engine developed a knocking during the afternoon session after a fill up. I put it down to dodgy fuel so drained it all out and changed the plug. Next trial no knocking and allseemed well. Yesterday it started to do it again... after lunch, it also seemed to be hunting a bit on tickover, which I thought could mean she's running a bit lean, but it does seem to be one of the more 'smokey' bikes despite being run on EXACTLY 70:1 (use syringe to measure)
Any thoughts guys ?
Rob
when you say "knocking" do you mean a mechanical knock or a ping type sound as in pre-ignition?
if the latter try a de-coke of the piston crown and the head, if the noise persists try checking the float level, then one size bigger on the pilot jet (you will need to re-set the air screw when the bike is hot).
i know from experience that these can be a pain to set up on the carb.
good luck, hope this helps.
paul.
Edited by paul w
