arun1664 Posted April 1, 2008 Report Share Posted April 1, 2008 Hello Just brought a TY 175 and have a couple of questions I hope people can help with: 1) When I change gears with the bike up on a stand and rotating the rear wheel by hand the lever sometimes sticks (i.e. it doesn't return to center). Pretty sure the return spring is OK. Any ideas if this is a known problem (or a problem at all) and if so what is the fix? 2) Also, what is s good transmission oil, I am used to putting ATF in my Beta, does this work for the old stuff ? Thanks in advance, Mike Quote Link to comment Share on other sites More sharing options...
29r Posted April 2, 2008 Report Share Posted April 2, 2008 Not sayin' tis... Remove the shift shaft cover and inspect . It's actually a remote ( so to speak ) and can get froze up , do to lack of lube . Gu'Luck Quote Link to comment Share on other sites More sharing options...
