barfy Posted April 5, 2008 Report Share Posted April 5, 2008 Can anyone advise on socket size for the 2006 4rt nut that holds on the clutch basket? I've tried 27mm, but it seems a bit loose and 26mm isn't big enough. I don't want to round the edges of the nut by using the 27mm because I'm sure that it's at toque setting FT 5. Many thanks Quote Link to comment Share on other sites More sharing options...
cadman Posted April 5, 2008 Report Share Posted April 5, 2008 Just looked in my manual & it lists the part as 90201-NN3-000 Nut, 18mm so I'd suspect a 27mm spanner would be a bit loose :-) However I havn't taken my clutch basket off so I can't say for sure what it is. have you checked your manual, I have an 05 & 06 and they say the same. I suspect your 27mm socket might be a bit stretched? or maybe low cost brand? I recently bought some new sockets that work onthe face of the hex, work great!. Good luck. Quote Link to comment Share on other sites More sharing options...
oz thumper Posted April 6, 2008 Report Share Posted April 6, 2008 Not sure of the size, however on any nuts that are tight it is a really good idea to use a straight hexagon socket, such as those sold as impact sockets, it is virtually impossible to round off a nut with the right size single hex socket. Quote Link to comment Share on other sites More sharing options...
barfy Posted April 6, 2008 Author Report Share Posted April 6, 2008 Thanks for the replies. I normally don Quote Link to comment Share on other sites More sharing options...
