godzilla Posted April 18, 2008 Report Share Posted April 18, 2008 (edited) I am going to replace the headset bearings in my 05 sy as the steering is notchy. cant i get them from a bearings dealer (if so has anyone got a part number) or is it a birkets job? Edited April 18, 2008 by godzilla Quote Link to comment Share on other sites More sharing options...
peterb Posted April 19, 2008 Report Share Posted April 19, 2008 Hi godzilla, You should be able to get these from a bearing supplier. Bottom bearing could be a bit tough to get off, may need a cold chisel to split the inner race. Pack with water proof grease, Mobil HP or similar. Check if there is some sort of water seal on the top bearing, a plastic cup or large O ring. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
