Scorpa Headset Bearings
godzilla
I am going to replace the headset bearings in my 05 sy as the steering is notchy. cant i get them from a bearings dealer (if so has anyone got a part number) or is it a birkets job?
Edited by godzilla
Hi godzilla,
You should be able to get these from a bearing supplier. Bottom bearing could be a bit tough to get off, may need a cold chisel to split the inner race. Pack with water proof grease, Mobil HP or similar. Check if there is some sort of water seal on the top bearing, a plastic cup or large O ring.
Bye, PeterB.
