jza Posted April 20, 2008 Report Share Posted April 20, 2008 I've got a new 6mm bashplate ready to fit, bought off H&D racing on fleebay. Looks like a great improvement The instructions suggest tightening the front bolts on a bit, then lining up the rears. Thing is, the angle of the front of the plate is such that the rear bolts are about 1/2 and inch off. The 6mm metal doesnt want to bend at all. How on earth do i bend it in to place? How should i angle the bike when working on it? Lie it on its side? Any ideas guys? Jza Quote Link to comment Share on other sites More sharing options...
eiaprilia Posted April 20, 2008 Report Share Posted April 20, 2008 it took me and my dad to get mine on, it was a right royal pain in the ass!! bolted it on at the rear then used a log to wedge under the front of the plate, my dad used his weight to bend the plate while i got the bolts in. good luck dude Quote Link to comment Share on other sites More sharing options...
scorpaf Posted April 20, 2008 Report Share Posted April 20, 2008 Use a ratchet strap under the sump and over the seat - might be worth protecting the strap from the sharp edges of the sump guard with a bit of carpet or cardboard. Quote Link to comment Share on other sites More sharing options...
jza Posted April 30, 2008 Author Report Share Posted April 30, 2008 Used my ratchet strap and some carpet, tightened up and pushed a bit and got it on.. phew... thanks for the responses guys Quote Link to comment Share on other sites More sharing options...
perce Posted May 1, 2008 Report Share Posted May 1, 2008 I've just fitted a H&D plate for the SSDT. Bolted it on at the front first & then the rear, no straps needed as it was a drop fit. Quote Link to comment Share on other sites More sharing options...
