Gasgas 03 125 Air Screw,how Many Turns?
dabomb
Hi all,can anyone tell me the correct amount of turns the air/mixture screw should be on an 03 txt 125 pro??
Cheers
o
Generally, it will vary slightly according to jetting (pilot/slide cutaway) and ambient weather conditions, so the best setting is what ever that particular engine needs. Start about 2 turns out to start (initial setting is somewhat irrelevant) and (warmed up engine) blip the throttle from idle and turn the screw in/out to get the best response, then you're set.
Cheers
Jon
